Discussion topic: Broadband issues
Message posted on 19 Dec 2025 09:24 AM
Broadband issues
Done Wi-Fi test and it says it's good but it isn't letting me on internet then when it does it just buffers
Message posted on 19 Dec 2025 09:57 AM
Re: Broadband issues
@Xtina84
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
