Discussion topic: Broadband issues
This message was authored by: Gromowski45
Broadband issues
Although the test through my sky says everything is ok, my hub isn't working at all, no lights, nothing.
Re: Broadband issues
@Gromowski45 See the link below and take what you need from there.
@Gromowski45
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
