Discussion topic: Broadband issues
Message posted on 05 Feb 2025 11:30 AM
Broadband issues
My broadband goes on a daily basis and I work from home and I'm paying for a service which dosent work.
Message posted on 05 Feb 2025 11:36 AM
Re: Broadband issues
I presume you mean it goes off?
If the service checker is still not telling you that Sky are aware you may need to call them to report it (dial 150 free from your Sky Talk landline). Remember that wfh brings no additional support or earlier appointment.
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
