Discussion topic: Broadband issues
This message was authored by Ilario This message was authored by: Ilario
Broadband issues
My connection is an ongoing spinning. Very disappointed
Re: Broadband issues
@Ilario Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Ilario
An engineer came around but he didn't fix anything
@Ilario  Did they give you any indication that it would need someone else to look at this. Was this engineer from Sky or Openreach?
Ilario
Openreach and he didn't tell me anything but the connection was ok. However, the issue is still there. I move to sky to get an improvement. They really let me down
Ilario
Could  be the router th problem?
Changing ISP cannot by itself resolve an underlying issue in the Openreach infrastructure.
