Discussion topic: Broadband issue
This message was authored by: Lucy203
Broadband issue
My broadband keeps dropping constantly over the last 48 hours despite all checks coming back ok. Please can you look at this asap as I work from home. Thanks
Re: Broadband issue
@Lucy203
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer led discussion forum where we try to help other Sky customers.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
