Discussion topic: Broadband issue
Message posted on 21 May 2024 05:49 PM
Broadband issue
Message posted on 21 May 2024 06:48 PM
Re: Broadband issue
@Nh987 your hub has lost its connection to the exchange. You can find out if Sky are aware of a fault in your area by running the connection test in the My Sky app over a mobile connection but dont be caught out bybthe result of the last routine test it ran some hours ago click to make tge test run again.
If there isnt a known fault give Sky a call to report the fsult so they can get Openreach check out what is wrong.
Message posted on 21 May 2024 07:24 PM
Re: Broadband issue
Message posted on 21 May 2024 07:51 PM
Re: Broadband issue
@Nh987 If its an issue in your area it will be fixed as rapidly as the engineers can do the work but nobody can give you more than a guess as to how long that can be including Sky.
