Discussion topic: Sky hub output is only 100mbps - I have 900 mbps at the house according to sky
This message was authored by TomB22 This message was authored by: TomB22
Can someone help. The output from my hub is around 100mbps even though I have 900 mbps at the hub. That's via an ethernet cable. WiFi is a bit slower
Re: Sky hub output is only 100mbps - I have 900 mbps at the house according to sky
@TomB22
Is it a Cat5e ethernet cable to a device which definitely has a gigabit ethernet port? Only seeing 'around 100mbps' should always raise suspicion that there's a 100Mbs limit somewhere (which, for example, can be caused by inadvertently using a four-wire cable)
