Discussion topic: Broadband issue no internet access
Message posted on 06 Feb 2026 05:16 PM
Why are your checks saying g everything is ok when I know there is an issue with my connection. Something has happened to the pole on the street with all the cables. I don't think I have connectivity but your checks say I have?
Message posted on 06 Feb 2026 05:17 PM
Re: Broadband issue no internet access
@EamonnRC
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
