Discussion topic: Broadband isnt working
This message was authored by: Katrina_7
My broadband isnt working
Re: Broadband isnt working
@Katrina_7
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
