Discussion topic: Broadband is regularly dropping out
This message was authored by JB980980 This message was authored by: JB980980
I have only been with Sky for a couple of weeks and the broadband has been terrible. Made 3 calls to helpdesk and had a visit from a broadband technician but no improvement. Broadband drops out multiple times a day, probably every 30mins. here are the router stats...any help would be much appreciated. thanksPicture2.jpg
Re: Broadband is regularly dropping out
@JB980980  Do any of the lights change on the router when these dropouts happen. Where do you have your router situated?
This message was authored by mae-3 This message was authored by: mae-3
@JB980980
The router stats don't reflect that and show it's been up for 2 days 5 hours. And it looks like one is using wireless, for increased range, and throughput across wireless one needs to purchase another third-party router which is generally more reliable.
The performance then hits a wireless limit and then we need more research. 😀
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
JB980980
Hi, all the lights remain green, Ethernet and WiFi both drop out. WiFi connection remains strong but I get the message no Internet. Thanks
@JB980980
So, you cannot ping the router at all, which indicates you have a faulty router it needs replacing. I will escalate if you confirm it by pinging '192.168.0.1' and posting the reply?
Hi @JB980980
Your stats suggest you are not using ethernet at all. What is your ethernet setup? To me it just sounds like you have WiFi interference which isnt a fault as such you'd just need to try and tweak your setup.
I am NOT a Sky Employee
