Discussion topic: Broadband is not working
This message was authored by: Omar85
My broadband is not working
Re: Broadband is not working
@Omar85
If the service checker is still not telling you that Sky are aware you may need to call them to report it (dial 150 free from your Sky Talk landline). Be aware that the overnight storm will have caused problems nationwide and the call volume to Sky and other ISPs is going to be far greater.
