5
This discussion topic has been answered Discussion topic: Broadband is down
This message was authored by: James562
Broadband is down
I've lost broadband connection today at 3:05pm. It went of with no warning. The router is showing 2 amber lights and 2 green lights. This happens periodically it other times it usually after midnight in maintenance periods. It would be nice if warning could be provided when this is going to happen or if unable to warn send out emails over the phone network
Re: Broadband is down
@James562
There is NO pre-warning of overnight maintenance.
@James562
Avatar for James562
2 red lights
3rd time this week my connection has dropped at 12pm. Every check says everything is ok. The first 2 times it came back up within 45mins. You can't tell me this is not an issue and somebody hasn't dropped these connections for a maintenance reason. Frustrating thing is they give no warning. I was bidding on live auction items at the time. Very poor service provider that does not make customers aware of maintenance issues
Re: 2 red lights
I'm not aware that any domestic ISP does so, nor do they make any offer of uninterrupted connectivity.
Re: 2 red lights
@James562
Probably not maintenance as that tends to be done between midnight and 7am to minimise disruption, again no advanced notice is given for this either.
Edit: I've merged your post into the thread you started a few days ago where you were advised there is no advanced warning of any maintenance.
Avatar for James562
Thank you Daniel - Very useful advice.
