Discussion topic: Broadband is down
This message was authored by: Tan14
Broadband is down
Sky broadband is down in Manchester area. Any information in regards maintenance work ?
Re: Broadband is down
@Tan14 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Avatar for Tan14
Thank you for your response. I ran a service check and unfortunately not responding. The engineer booked for next Tuesday only.
