This discussion topic has been answered Discussion topic: Broadband installation problems
Message posted on 28 Jan 2024 08:20 PM
My broadband was supposed to go live on Friday, however there were two issues. The hub was delayed, and only delivered Saturday. But the engineer failed to connect us. He's left and I've had no contact since. He said he wasn't able to access the problem and would have to get someone else out to sort it. Does anyone know how long this will take
Message posted on 28 Jan 2024 09:00 PM
So ideally there will now be an underground trained engineer request to visit tomorrow or tuesday
did the engineer complete the internal work so you are able to connect the hub ready to go active?
Message posted on 28 Jan 2024 08:28 PM
Re: Broadband installation problems
Openreach have a service level agreement of provoding sky with an update or resolution within 72 working hours
hopefully the engineer that failed to complete your installation has raised this with his employer, openreach, so the appropriate fix or engineering solution is booked in and completed within that time scale
dis he give you any more information or just that vague no access answer?
Message posted on 28 Jan 2024 08:54 PM
He said he could vaguely hear the connection, but he wasn't able to connect it up. He said they should be able to get underground and connect it, that was all.
Message posted on 28 Jan 2024 09:06 PM
Yes he did do that, so fingers crossed tomorrow then? Thank you for the reply
Message posted on 28 Jan 2024 09:08 PM
If if goes beyond the service level agreement timescale then sky order recovery team will be assigned the case to investigate as late completing and you will start to receive updates via text as sky gets them from openreach
Message posted on 28 Jan 2024 09:10 PM
The service level agreement being that is has to be activated within 72 hours, so openreach will be aiming to get it completed tomorrow?
Message posted on 28 Jan 2024 09:18 PM
Working hours so the weekend doesn't count with openreach
Message posted on 29 Jan 2024 07:26 AM - last edited: 29 Jan 2024 07:33 AM
Be aware that if a duct is blocked and requires digging, all bets are off as to timescale because unfortunately that process requires the availability of a different team and can be extremely prolonged, particularly if external permissions are required. The Ofcom compensation scheme for delayed activation should apply.
Message posted on 29 Jan 2024 08:46 AM
The engineer mentioned he could hear the connection, but couldn't quite link it up. If that means anything?
Message posted on 30 Jan 2024 10:28 AM
I've not heard anything still, is this normal
