Discussion topic: Broadband fault
Message posted on 14 May 2025 12:21 PM
							Broadband fault
My internet connection keep dropping off had no connection at all this morning help please
Message posted on 14 May 2025 12:32 PM
							Re: Broadband fault
@Greyday1
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If you’re still having problems you may need to call Sky to report it.  Dial 150 free from your Sky Talk landline (if it’s still working).
