Discussion topic: Broadband drops out every 5-10mins and reconnects within a minute, incredibly annoying.
This message was authored by JamesR97 This message was authored by: JamesR97
I have ran all the Sky "tests" (which I know for a fact are inaccurate, ofcourse there are no problems when its connected, stupid test)
Please help.
JamesR97
Re: Broadband drops out every 5-10mins and reconnects within a minute, incredibly annoying.
Look at this "oops that didnt work, looks like our tests are unavailable" um no, your crap internet just keeps disconnecting MID TEST
@JamesR97 If your connection is still playing up this morning call Sky to report it issues after midnight can nbecdue to maintainance in which casecthings should be back to normal.
Sky's connection test measures the speed the modem is connected to the line assuming you have a seervice over a copper line and are accurate. If the connection drops the test wont work which if you think about it is pretty obvious but the test can tell you if there is a known issue in your area. The test works over a mobile connection. Full Fibre connections dont return the speed as the modem is not used but fibre speeds should always be what you are paying for as they dont vary due to line length etc..
You can check the connection speed on the modem youself by looking at the connection stats see Find your Sky Broadband router statistics
If you consider that the test is inaccurate because speed tests on devices are lower the explanation is simply thst the connnection from the hub to the device is slower.
JamesR97
Hi,
What number do I call please?
Thanks,
James
@JamesR97  If your landline is working then dial 150. If you are calling via mobile and don't have Sky mobile you can use the number at the bottom of the link below under " Need more help ".
https://www.sky.com/help/home
JamesR97
Help me understand what this means please
Recently I posted this thread https://helpforum.sky.com/t5/Broadband/Broadband-drops-out-every-5-10mins-and-reconnects-within-a-mi... and im still having the issue, though I have just checked the Sky logs after it happened and this is what came up:
02:10:33 syslog: WAN IPV6 UP
02:24:27 syslog: [174988.694000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
02:24:30 syslog: [174991.725000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
02:25:05 syslog: [175026.844000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
02:25:08 syslog: [175028.873000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
02:25:38 syslog: [175059.079000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
02:25:40 syslog: [175061.093000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
02:26:10 syslog: [175091.226000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
02:26:12 syslog: [175093.247000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
02:26:42 syslog: [175123.445000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
02:26:44 syslog: [175125.473000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
02:26:53 syslog: Administrator login successful from IP: *removed*
So my understanding is that this is constantly disconnecting and coming back up, 4 times within 3 minutes? What might be causing it?
Thanks!
JamesR97
Re: Help me understand what this means please
the 😎 emojis are just Port: 8 )
JamesR97
I have followed this https://www.technology.pitt.edu/help-desk/how-to-documents/pittnetwired-configuring-windows-10-wired...
section 2 - "Modify the Ethernet Card Speed and Power Management" and I have now set the duplex speed to be permanent. I hope this fixes it.
