11
This discussion topic has been answered Discussion topic: Broadband dropping
This message was authored by: zm4
Broadband dropping
Last 3 days now, broadband will drop every so often, feels like it's getting more frequent - few times an hour. Only drops for a couple of minutes at a time, broadband light flashes amber then reconnects. Broadband status test shows nothing wrong - reconnects by time test is complete, but keeps cutting me off work calls and losing connection to work server so having to redo tasks. Anyone else had this issue? Spoke to sky on phone and they say nothing wrong with the line.
here's the log from router when it happened earlier:
09:35:14 syslog: ptm0.1 - WAN link DOWN.
09:35:14 syslog: DHCP lease invalid(WANoE). Connection DOWN.
09:35:17 syslog: Clear IP addresses. IP connection DOWN.
09:35:19 syslog: Voice IP Connection Down
09:35:19 syslog: [44030.498000] Line 0: xDSL link down
09:35:19 syslog: [44033.556000] Line 0: xDSL G.994 training
09:35:21 syslog: Voice Disconnected
09:35:27 syslog: Voice DeInitialized
09:35:27 syslog: [44041.561000] Line 0: VDSL G.993 started
09:35:44 syslog: [44057.571000] Line 0: VDSL G.993 channel analysis
09:35:44 syslog: [44059.492000] Line 0: VDSL2 link up, Bearer 0, us=16995, ds=29997
09:35:44 syslog: [44059.492000] Line 0: VDSL2 link up, Bearer 1, us=0, ds=0
09:35:45 syslog: sky dhcpc client (v0.0.1) started
09:35:52 syslog: ptm0.1 - WAN link UP.
09:35:52 syslog: Received valid DHCP lease from server. Connection UP.
09:35:53 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D200196D018599/3C8994736910/90.193.1.167/7.04.0100.R/::]
09:36:03 syslog: WAN IPV6 UP
09:36:03 syslog: Voice IP Connection Up: 2a02:c7c:ad71:cc00::1/64
09:36:03 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D200196D018599/3C8994736910/90.193.1.167/7.04.0100.R/::]
09:36:05 syslog: Voice Configured
09:36:09 syslog: Voice Initialized
thanks
Avatar for zm4
This message was authored by: zm4 Answer
Re: Broadband dropping
Just to finish this thread off - engineer came today and found the old line was faulty. New line put in place and all is back well again.
@zm4
That log is showing 29 Mbps download and 17Mbps upload . So looks like something is wrong
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
To report the issue
@zm4 Would also have a quick look at you stat's as you may have a noisy copper line, or a home fault!
How to read your Sky Hub statistics
Avatar for zm4
Thanks for the reply. Hopefully these are what you mean - I'm a complete novice at this stuff.
@zm4
The down stream noise margin is sky high you should be getting 65-80Mbps
Call sky per my link above
@zm4 You did well, follow @cookiemonsteruk guidance and call sky, have them run the line check and advise you what they want to do. Not going to get better if you do not deal with it.👍
Avatar for zm4
Thanks for the replies. Just an update to this - Sky sent a new router which hasn't changed anything. They tried to run a line test over the phone but kept getting an error in just trying to run the test. So now I have to wait for them to sort their test out before they'll call an engineer out.
@zm4 Think the new hub sent was a clutching at straws for that as a fix, and hopefully you do not have an internal home wiring issue and that it is all external, the noise level that is showing is an openreach engineer visit to find and fix type situation. As you say keep the Forum updated with the outcome, it just may be an easy sort for the engineer to find and fix!
Avatar for zm4
@zm4 Give a week to settle in, then grab your stat's like before, you will have a reference to compare for future use.
This message was authored by: Freya28
My broadband is dropping I've paid my bill and my next bill is not due till the 19th December
@Freya28 This thread although the heading is true, was for a copper line issue that was never going to be fixed without an OR Engineer's visit, if you wish to follow it look and see as all the links then please do so. Your line dropping off can be for just many reason's the one you put for sure!
