Discussion topic: Broadband dropping
Message posted on 04 May 2025 12:00 AM
Broadband dropping
Broadband keeps dropping off have done everything like switch on off unplug reconnect still happening
very annoying
speed is too slow
unable ti watch sky
Message posted on 04 May 2025 12:04 AM
Re: Broadband dropping
Very annoying can not watch sky
cisting £95 a month fir no sky outragious
Message posted on 04 May 2025 06:40 AM
@Mcjc You are never going to have 100% uptime on your connection and from time to time your connection will drop. Can you follow the directions below to see if a fault can be found.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
