Discussion topic: Broadband dropping out
This message was authored by: Willie58
Broadband keeps dropping out and also on the to.
Re: Broadband dropping out
@Willie58
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: Nuttynagle
Broad band keeps dropping out on all devices  
had new router the same problem.  Check with your own checker you say all connected and no thing wrong but no devices connected. There are five devices that say they are connected to WiFi and two via cable please help
