Discussion topic: Broadband dropping out
Message posted on 21 Jul 2025 09:22 PM
Message posted on 22 Jul 2025 04:42 AM
Re: Broadband dropping out
@Kathylegg2010
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Message posted on 22 Jul 2025 07:06 AM
@Kathylegg2010 Easiest is use your landline phone and call sky, 150 have them do a diagnostic check on the line for you, and if it is found faulty then they will organise anything that is required!
