Discussion topic: Broadband dropping out
This message was authored by: fatbbaldsurfer
Since moving to sky a couple of weeks ago the broadband seems to keep dropping out. My wife works at home and her laptop drops the connection and then has trouble reconnecting. She has taken this up with her work who say it is not at their end. She is using the same laptop in the same place in the house, doing the same work as she was before we switched to sky. The only differenec is we are not with BT anymore. How do we get incontact woth Sky to sort this out as it is taking her 4 times as long to complete the tasks she has.
Re: Broadband dropping out
@fatbbaldsurfer
