Discussion topic: Broadband dropping out
Message posted on 06 Feb 2025 11:04 AM
I am working from home today but the broadband keeps dropping out
Message posted on 06 Feb 2025 11:35 AM
Re: Broadband dropping out
@Ryboy222
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
