Discussion topic: Broadband dropped
This message was authored by: 17chelmsford
Broadband dropped
Broadband dropped reset and is not working
Re: Broadband dropped
@17chelmsford
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
This message was authored by: KimGale
My service is horrendous. I have had numerous engineers out over the last few months and all say they have fixed it. Lasts a week or 2 then reverts back to dropping out every 10 mins. Today it's dropped in excess of 20 times which is not ideal when I'm a home worker. Really fed up with this now.
