Discussion topic: Broadband down
This message was authored by: Becks1304
Broadband down
I have followed all the steps and the internet is not working. It has been off since 10pm last night. I work from home and need access
Re: Broadband down
@Becks1304
Sky broadband being discussed here is a domestic service and whilst it's fine for those customers wfh to use it they won't receive additional or quicker support.
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
