Discussion topic: Broadband down
This message was authored by: WRG99
Broadband down
Internet connection not working but says it's all good on the checks
Re: Broadband down
@WRG99
Try a reboot of your broadband hub at the mains.
This message was authored by: AliH63
Re: Broadband down
Getting same issue.
This message was authored by: ali+carpenter
Re: Broadband down
  • Yes. Internet light amber
Re: Broadband down
@ali+carpenter
This message was authored by: AlistairHayman
Re: Broadband down
Me too. Is it local to Bath area?
Avatar for WRG99
Re: Broadband down
Tried this already still no help as all the checks are saying my connection is ok but it's not
Re: Broadband down
This message was authored by: Steven132
Re: Broadband down
I'm having the same problem. Amber static light in the middle. Diagnostic checks say everything is fine. Sky pretty useless, phone the number and they say to go through online steps.
This message was authored by: Gds
Re: Broadband down
I'm in Bath area with the same problem.
Avatar for WRG99
Re: Broadband down
Yes me too, mine is back on now
This message was authored by: Jingle141
Re: Broadband down
I'm in Bath, the internet has been down for about an hour. When I first do the broadband checker it shows an issue, click 'let's fix that' then when it does more tests it says everything is good no issues in the area and 'your devices and set up' is good - despite it also saying no devices are connected.
Re: Broadband down
Seems to be back up and working now.
