Discussion topic: Broadband down in hd3
This message was authored by: AdeleT
It says there are no issues but I have no broadband
Re: Broadband down in hd3
@AdeleT
For a no broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Avatar for AdeleT
Level 0 icon
I have it says there are no issues
Hi @AdeleT
What lights are showing on your hub at the moment?
Are all of your devices not working or just some?
I am NOT a Sky Employee
@AdeleT
Please complete all of the advice above. You may then have to call Sky as we are fellow customers on here.
