Discussion topic: Broadband down Green light on
This message was authored by: Daz+Yorkshire
Message posted on 08 Mar 2025 09:34 AM
My broadband is down but the green light is on, I've run the tests they come back fine, I've powered down and reset multiple times.
How do I get in touch with Sky, the virtual assistant is useless just loops you round and I can't get past the AI telephony system who says I can record the fault online, but that is only possible when their test identifies a fault, its shouldn't be this difficult to get help.
Find out more
Message posted on 08 Mar 2025 09:52 AM
Re: Broadband down Green light on
When calling stay silent when asked anything by the bot and remain on the line as that should get you through to speak to someone.
