Discussion topic: Broadband doesn’t work
Message posted on 02 Nov 2025 08:19 PM
The router shows no light for the internet and red light for voice. There is no broadband connection on my laptop or my mobile phone
Message posted on 02 Nov 2025 08:26 PM
Re: Broadband doesn’t work
@JustynaG
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
