Discussion topic: Broadband crashing
This message was authored by: Paula10
Broadband crashing
Hi since my new fibre elastic Internet as being connected it keeps crashing or just not loading
Re: Broadband crashing
@Paula10 Does this show anything on the hub?
Avatar for Paula10
Not sure there all flashing fast
@Paula10 What hub do you have? and what is the state off the lights!
Avatar for Paula10
Sorry can't send pic
@Paula10 You do not need to send a pic, just explain what you see for all the light's. And say WHAT hub it is that you have!
Avatar for Paula10
Not sure wat hib and end green lights flashing fast
@Paula10 Sorry you where sent a link earlier in the post, it shows you all the hubs, tells you all about the lights so use that link!
Avatar for Paula10
Sky broadband hub
@Paula10 And is it the power light very left as you look at it that is flashing green?
Avatar for Paula10
Oh no it's have a white box on wall newly fitted fibre fast it's thst light
@Paula10 Last light on the little box on the wall, very right hand side one, has the word LAN under the light, it flashes as the hub sends data back and forth so it is correct that it flashes, POWER is a solid GREEN, PON is a solid GREEN, LAN is a flash on/off and varies with speed etc, and the LOS is normally OUT no light.  That is all the normal conditions......
Avatar for Paula10
  • Well not sure why it keeps crashing
@Paula10 You now know what to see when the little box is in a working condition.... That box is called the ONT Optical Network Terminal...
When you have the fault you can just look at the sky HUB next time, normally it's a 4 green lights across the board for a fully working hub.
Should you have an issue then say what you see then. If broadband fails expect the Internet light 2nd from the left to go Amber or out, phone normally follows suit but goes solid amber last light on the very right.
The link shows you all the sequence and steps off the lights.....
@Paula10
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
