Discussion topic: Broadband connection lost
Message posted on 17 Jan 2026 09:04 PM
Message posted on 17 Jan 2026 09:25 PM
Re: Broadband connection lost
@Ramakumar Not much to go on with your post, see if any off the help does anything for you!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
and you can do this if not too early yet!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
