Discussion topic: Broadband connection issue
This message was authored by: Freya6
Message posted on 18 Apr 2024 08:23 AM
Can't connect to the broadband says there is an issue with the connection although I followed all the steps and is connected right
Find out more
Message posted on 18 Apr 2024 08:35 AM
Re: Broadband connection issue
@Freya6 likely to be a line issue which are far more common than normal due to bad weather. If the app said Sky are aware then it will be fixed however if it didnt give them a call.
