Discussion topic: Broadband cable
This message was authored by: Chloe780
Broadband cable
I am trying to connect my broadband but unfortunately the cable you have sent me is too short for me to be able to plug it in is there any way I could have a much larger cable in length
Re: Broadband cable
@Chloe780
What connection are you getting superfast fttc or ultrafast fttp
What cable were you sent . Ethernet or a dsl cable?
Are you trying to extend the distance between mastersocket/ont
Avatar for Chloe780
Re: Broadband cable
It's the superfast broadband but I would need at least 5meters
Re: Broadband cable
@Chloe780
If it is superfast broadband via a traditional mastersocket the you are looking for a rj11-rj11 dsl cable.
However superfast can be delivered via fttp with an rj45-rj45 ethernet cable from the ont to the sky hub and can be bought at currys, dixons , argos etc for about £5-£10
The distance would not be a problem either
Avatar for Chloe780
Re: Broadband cable
It's the cable with the plug that I need an extension on not the connection wire the one you plug into the socket
Re: Broadband cable
@Chloe780
What hub do you have?
Sky  don't supply longer power cables
You could use either of the cables depending on your connection type to extend the hub location closer to the desired electric power socket
Avatar for Chloe780
Re: Broadband cable
Re: Broadband cable
@Chloe780
You could have a look at myvolts they may have longer lengths of the power cable. Just give them the model number on the back of the hub ie sr203 etc
https://myvolts.co.uk/
Re: Broadband cable
@Chloe780
It is not recommended to try and extend the power lead for the Sky hub. If you need it to reach further you should use a power strip.
I am NOT a Sky Employee
