Discussion topic: Broadband and landlines issues
This message was authored by: Clairachuff
Landline stopped working at 10 am and at 12 broadband is dying. Also at 2 broadband fully died no internet
Re: Broadband and landlines issues
@Clairachuff
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
