Discussion topic: Broadband & WiFi
Message posted on 13 Mar 2025 03:10 PM
Broadband & WiFi
I've had sky for a month, 2 weeks without internet, yet I've paid about £200.
somethings wrong with the broadband itself and the WiFi, even tho bills are paid.
Message posted on 13 Mar 2025 03:23 PM - last edited: 13 Mar 2025 03:24 PM
Re: Broadband & WiFi
So have you rung Sky to report this in the last two weeks? (And you won't have paid £200 for broadband in a month).
Message posted on 13 Mar 2025 03:28 PM
I've tried phoning and every time I do it says user busy. And yes I have proof I've paid around £200 as I've had sky for a month and 2 weeks but I haven't been contacted to the WiFi for 2 weeks. And yes I've followed the guild lines on following the steps, I try it everyday and still nothing.
Message posted on 13 Mar 2025 03:31 PM
Then you'll need to persevere on the phone. The call centres will be busy and will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 13 Mar 2025 03:32 PM
Right will give it a try, but when I ring doesn't even let me stay on the line
Message posted on 13 Mar 2025 03:34 PM
In case your calling an incorrect number I'll add this link…
To call Sky dial 150 (free) from your Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
