Discussion topic: Broadband activation
Message posted on 01 Sep 2025 08:36 AM
Hiya I have just recieved my sky hub broadband but haven't moved into the property yet the broadband activates today 1st September but we move on the 12th will this still be okay? Any help will be appreciated
Message posted on 01 Sep 2025 08:41 AM - last edited: 01 Sep 2025 08:46 AM
Re: Broadband activation
@katie273 Service will be activated, but you will not know if done successfully until you get there and connect up the Hub to the service!
As you do not say or if you do not know what is being done, if Engineer is required to be inside the property and you have been advised off that then it will be marked up as such, if you receive text from OR/Sky you are all connected and you can now install the hub then when you do get round to it on the 12th or later then that's the time!
