Discussion topic: Broadband / WiFi down again
Message posted on
19 Aug 2025
01:35 AM
- last edited:
19 Aug 2025
09:25 AM
by
Nimbob
It's down again, how many times. Fibre , WiFi , states on checker all good ... [Removed]
Moderator note: Removed inappropriate remarks
Message posted on 19 Aug 2025 05:33 AM
Re: Broadband / WiFi down again
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down later, and you haven’t done it yet, use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
