Discussion topic: Slow Fibre Broadband Speeds
Message posted on 13 Aug 2025 06:06 PM
I'm on broadband ultrafast plus and doing a speed check I currently get around 250mbps. Checking it on my xbox series x when downloading a game recently it sits at 75mbps.
I've reset the router and rest the internet setting on xbox and still same result, the router is in the livingroom and the xbox sits in the same room but still the speed is under 100mbps. What else can be done with this?
Message posted on 13 Aug 2025 06:35 PM
Re: Slow Fibre Broadband Speeds
@Stuarty1877 You know not what the download server is/was capable off, and wired ethernet may get you a little quicker but you will not know until you try!
Message posted on 19 Aug 2025 09:44 AM
Not sure where you are, but I am in Ireland on Siro, and I am seeing 100Mb where I should have 1Gb. I have seen a lot of the carriers carrying out engineering work for the last few days, so I suspect that this may be part of that. Pity Sky cannot confirm if they are doing engineering and when things will return to normal!
