Discussion topic: Broadband Router not connecting to Sky Box
Message posted on 02 Dec 2025 11:38 PM
Sky router won't connect to Sky Q Box or Mini Boxes.
I have tried to reconnect and reset none of which has worked
Message posted on 02 Dec 2025 11:49 PM
Re: Broadband Router not connecting to Sky Box
@Tracy601 Sky Broadband hub the black one, or the sky Max hub the white one, second post tonight with Q issues?
Message posted on 03 Dec 2025 12:17 AM
White one
Message posted on 03 Dec 2025 12:24 AM - last edited: 03 Dec 2025 12:28 AM
@Tracy601 Ok, white one is not good with the sky Q/mini options and is nothing to do like the earlier post if you come accross it, so going to link the information, you now need to treat the network as a NON sky connected mesh, Q and the mini are the only two that go together!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
and the sky Max below if you need to look at anything specific.
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
If you find that you cannot make it all work then you will need the assistance of a sky TV / sky Q/mini expert, they will require to bolster the mesh network between the sky Q and the sky mini with an older sky Booster now if you are trying to do this all wireless wifi connected!
