Discussion topic: Broadband Provider
Message posted on 01 Dec 2024 10:46 AM
Broadband Provider
I have FTTP and my question is...if I have 150mb full fibre broadband does it matter who the provider is for this, as I believe (BT) open reach are responsible for getting it to your property and after that you are just essentially plugging in a router and connecting devices.
You obviously have Sky then BT, EE, VODAFONE etc etc as service providers which should all be able to provide the same broadband service.
Is the main difference going to be on the customer service side of things should you have any problems or are there any other factors to consider. Thanks
Message posted on 01 Dec 2024 01:14 PM - last edited: 01 Dec 2024 02:06 PM
Re: Broadband Provider
That is essentially correct: all Openreach client ISPs are reselling the same wholesale broadband products.
In addition to the customer service you mentioned, ISP router hardware can vary quite significantly.
