Discussion topic: Broadband Outage in Essex 24th May 2025
Message posted on 24 May 2025 02:08 PM
Thread created with tilte to reflect current issue
Message posted on 24 May 2025 01:39 PM
Wifi not working
Message posted on 24 May 2025 01:42 PM
Re: Wifi not working
@Slavka
The Sky Community is a customer led discussion forum where Sky customers are available to help other customers. You are NOT contacting Sky Customer Services by posting here.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 24 May 2025 01:44 PM
@Slavka Where in the UK are you
Message posted on 24 May 2025 01:52 PM
Sky WiFi Down
Message posted on 24 May 2025 01:58 PM
No internet
No internet connection although service checker says all ok! What's happening recently with sky - lots of outages and pay a lot of money for the 'service'. Im in Essex
Message posted on 24 May 2025 01:59 PM
Re: No internet
Message posted on 24 May 2025 02:01 PM
Re: No internet
yes I'm in Basildon too! Must be a problem that Sky are not admitting to!
Message posted on 24 May 2025 02:04 PM
Internet not working
My internet has been dropping out over the last few days. Today it has dropped out and I cannot get it to reconnect.
Message posted on 24 May 2025 02:06 PM
Re: No internet
Also in essex. Same issue. Getting frustrated now, it's not cheap!!
Re: Internet not working
@Cdonovan First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 24 May 2025 02:06 PM - last edited: 24 May 2025 02:07 PM
Re: Sky WiFi Down
@B-e-n-j
Some reports of issues in Essex if you're there.
Message posted on 24 May 2025 02:07 PM
Re: No internet
Re: Sky WiFi Down
Message posted on 24 May 2025 02:10 PM
Re: Sky WiFi Down
I'd already edited my reply.
