1
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: Cat6437
No wifi
Have gone through all necessary checks, broadband showing no wifi light.
Settings on sky is showing, status not connected, connection to Internet is showing x.
Have unplugged a rebooted, plus pressed wps on router, still on wifi.
Please help me to restore my services!
Re: No wifi
@Cat6437
There are apparently issues in Essex this afternoon if you’re in that neck of the woods.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Re: No wifi
@Cat6437
