2
This discussion topic has been answered Discussion topic: Broadband Issues
This message was authored by: Jamo82
Broadband Issues
[removed] so I pay for full fibre 500 and have problems getting any internet in the front of my house but if I pay extra and have max  I can get full fibre 500 with no issues I left virgin where I had no internet issues for this
Reason I left virgin as sky came in cheaper wish I hadn't bothered
Moderator Actions: Removed allegations
Re: Broadband con
Delivered over optical fibre and ethernet cable as far as the Hub.
Max is additional support for WiFi  rather than broadband.
Re: Broadband con
Not sure that is correct, as this is what Max gives you:
Sky will supply you up to 3 pods to help with issues like this with Max on your account.
Re: Broadband con
