Discussion topic: Broadband Issues
This message was authored by: AC-93
Broadband Issues
We joined Sky 2 weeks ago for broadband, first week was great and everything worked fine. However, this past week we can't connect to the WiFi for more than a few minutes at a time before it drops out. Everytime I 'test my broadband' on the app, it says everything is good but it's really not? We've even had a engineer out who's taken a look and said it's fixed but it's still not connecting... anyone had similar and is there anything we can do to fix this without waiting for another week for another engineer?
This message was authored by: JPR007
Re: Broadband Issues
@AC-93Your stats suggest you are on a G.Fast connection - but they do not show much up with it.
Are the devices in question connected via WiFi? I would assume they are as there is no LAN activity on the router.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for AC-93
@JPR007 the devices are via WiFi - the broadband check on the app states they are connected but you can't actually do anything on the devices as everything is just constantly buffering and not actually loading up
