Discussion topic: Broadband GU35 area
This message was authored by: Mick203
Broadband GU35 area
Once again the broadband in this area has dropped out and sky are saying on their site that there is no problem.
Re: Broadband GU35 area
@Mick203
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
