Discussion topic: Broadband DOWN AGAIN!!! B32
Message posted on 29 Jul 2025 02:53 AM
Broadband has now been off 4 hours as there is an outage in our area no clue how long it's going to take to fix it I sincerely hope it's not two days!!!!!! Paying £46 for this WiFi really not good enough I'm in B32 I'm disabled stuck at home so I really need reliable WiFi
Message posted on 29 Jul 2025 05:56 AM
Re: Broadband DOWN AGAIN!!! B32
@emma3ooo
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
