Discussion topic: Broadband 500
This message was authored by: Puddie73
Broadband 500
Swapped to 500. Only some devices connect and then the apps don't work on some but do on others.
Re: Broadband 500
@Puddie73 When you upgraded to the FF500 sky package, did you per chance also upgrade and do the sky Max hub at the same time?
Also go to your account and see what the Broadband Shield product is currently set at!
