Discussion topic: Broad band
This message was authored by: Bethany11
Broad band
My broad band isn't working
Re: Broad band
@Bethany11
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
