Discussion topic: Broad Band
Message posted on 22 Apr 2025 02:43 PM
Broad Band
Trying to study and WFH and Bb is down.
Message posted on 22 Apr 2025 02:47 PM
Re: Broad Band
@Ripoff4u
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
