Discussion topic: Booster not working
Message posted on 15 Jan 2025 09:57 PM
Booster not working
Booster not working. Can't reconnect????
Message posted on 15 Jan 2025 10:24 PM
Booster
Booster not connecting
Message posted on 16 Jan 2025 08:14 AM
Re: Booster
@PatrickGoad move the booster closer to the hub as it needs a decent connection to work. Ideally it should be halfway between the hub and where you need the boost.
However the boister dies need to be matched to the hub and the older Sky boosters will not connectvtomthe new white hubs.
Message posted on 16 Jan 2025 08:17 AM
Re: Booster not working
@PatrickGoad assuming you have not changed your hub try the booster in thecsamecroom as the hub if it won't connect there then the booster is likely faulty and needs replacing which Sky will do if they gave you the booster. However not all Sky boosters work with every Sky hub. The new white hubs require a different booster
Message posted on 16 Jan 2025 08:34 AM
Re: Booster
Your two other posts have been removed as you'd already posted this twice, both replied to by @Chrisee
