Discussion topic: Booster extendr
This message was authored by: Harpql
Booster extendr
Hi my extender and booster don't seem to work as the WPS button does not light up to connect my sky q mini box that has been repaced
Re: Booster extendr
@Harpql Dky Q minos will not connect directly to the white Sky Max hub or its pod extenders instead you connect them to the main Q box. If you have a black Sky Broadband booster you need a SE210 Sky booster (confusingly looks like a white version of the hub) with those Q minis should connect using WPS if in range.
